Rokon Trail-Breakers
Aucune réponse à ce sujet
#1 Stepquest
Stepquest
    Je suis ton père !
  • Gold Member
  • 16397 messages
  • Interests:Divers et variés
  • Ville :Val de Marne (94)
Posté 15 February 2005 - 16:39
Et oui, dès 1974, les américains avaient produit via une marque qui existe toujours, un moto à deux roues motrices :
rokon_trail_breaker_1974.gif 1974
Modèle militaire actuel :
Drive System Full time, front and rear wheel drive
Engine Kohler, single cylinder, four stroke, fan cooled
Piston Displacement 172cc
Power Output 6.6 HP at 4,000 RPM
Power Transmission Automatic torque converter into a three gear range selector
Speed Range 1st gear 0-10 MPH (16 kph)
2nd gear 0-22 MPH (35 kph)
3rd gear 0-40 MPH (64 kph)
Power Take Off 6.6 HP (est.), speed proportional to throttle setting
Fuel Tank Capacity 2.69 US (10.0 L) Hi-impact polyethylenc tank. Auxillary Fuel storage 4.5 US gallons (17 liters ) per wheel 2.5 US gallons per 12" wheel
Fuel Regular unleaded gas
Fuel Consumption 0.45 gal/hr (1.7L per hour)
Brakes Disc type, front and rear, dual handledbar mounted controls
Starter Automatic recoil
Ignition Electronic magneto
Electrical 12 volt with 90 watt alternator
Exhaust Muffler and US forestry approved spark arrestor
Carburetor Fixed Main Jet carburetor
Air Filter Dry type
Grade capability 60 percent
Weight 208 lbs. (94 kg)dray weight
Warranty 12 month Limited Warranty
Image(s) jointe(s)
Bannière basse
  Sujet Forum Commencé par Statistiques Infos sur le dernier message
